How to remove plastic nut on my toilet flush system?
jordoniums
Community Newcomer
What would be the best tool to remove this horrible plastic 'nut' on my toilet flush system!
I am trying to replace a leaking flush and this nut has been stubborn. I don't have a big enough wrench to get it moving and don't really want to buy one as they are expensive. Any sub $20 tool that would do the trick?
Jewelleryrescue
Re: What would be the best tool to remove this horrible plastic 'nut' on my toilet flush system.
Hi @jordoniums
Try  using thats what i use.
Craftright 250mm Multigrip Plier  I/N: 0154795  $9.98
https://www.bunnings.com.au/craftright-250mm-multigrip-plier_p0154795
It will all itself to adjust to that nut size.  If The tool plays up and changes size on you tighten the plier central nut a bit. Cheaper  hand tools can come back and bite you when under more pressure.
A  Better tool might be  as below as hand  tools can last you a life time.
IRWIN 250mm All Purpose Locking Groove Pliers I/N: 0280757  $39.98
https://www.bunnings.com.au/irwin-250mm-all-purpose-locking-groove-pliers_p0280757
Hi @jordoniums,
@Jewelleryrescue has already jumped in with the right advice.
Multigrips, such as the Craftright 250mm Multigrip Plier are the best option at a price point beneath $20.
Let me know if you've got any further questions.
