How to remove Caroma Flush valve?
I wanted to see if a new washer would stop the continuous trickle of water into the toilet bowl but the darn things is stuck as though it's glued on. It's a Caroma Smart Flush.
- Labels:
Plumbing
Repairing
Tools and Materials
Re: Removing Caroma Flush valve
Hello @Linnea
Welcome to the Bunnings Workshop community. It's sensational to have you join us and thanks for sharing your question about your Caroma flush valve.
Removing the flushing valve can sometimes be quite tricky. Some models are twist and lift, others have clips that you press at the bottom sides, and some have a combination of both. I suggest studying your flushing unit closely to see which locking system it uses.
If for example, it has no clips to press at the side odds are it uses a twist click system. But if you are worried about damaging your flushing valve, I suggest engaging the services of a handy person or a plumber.
