How to polish an acrylic bathtub?
AJ108
Good morning
i recently removed some essential oil stains from my acrylic bathtub using jiff and a fine grit sanding pad and a lot of elbow grease and it’s come up really well. I’m concerned that I have taken away a layer of protective coating in the process. I’m looking for a wax that I can apply to brighten and protect. The only Bunnings item I can see that might fit this description is autosol acrylic polish however I’m not sure if it’s suitable for bathtubs. Would this product do the trick?
thank you
Angela
Re: How to polish an acrylic bathtub?
Hello @AJ108
Welcome to the Bunnings Workshop community. It's sensational to have you join us and thanks for sharing your question about polishing your bathtub.
Acrylic baths come with a proprietary top coating that gives it that surface polish. It is technically possible to polish the surface of the bath, but it will not be a long-term fix. If you are looking for a permanent fix, I suggest engaging the services of a bath resurfacing specialist. They will have the knowledge and equipment to re-seal your acrylic bath in a more permanent manner.
However, if you are not yet ready to have your bath fixed, using the Autosol 75ml Acrylic Polish will temporarily polish the bath surface. I propose testing a small portion of the sanded area to make sure that it is compatible with the bath.
AJ108
Thanks Eric
Ill try the polish first.
