How to install bathroom wall mirror
Hi Everyone,
I am hoping that someone would be able to help me install a mirror on my bathroom wall tiles with noggins inside the wall. The mirror is 80cm x 92 cm (WxH) with some plastic brackets. I just do not know what screws, anchors, and drill bit to buy. If someone could help me, it would be much appreciated. I have attached photos of the wall, mirror, and brackets.
- Labels:
Renovation
Tools and Materials
Re: How to install bathroom wall mirror
Welcome to the Bunnings Workshop community @JakeC. It's terrific to have you join us and many thanks for your question.
Are you fixing the brackets into the tiles or are you screwing them into the timber studs/noggins?
If you are attempting to fix them into the tiles I would suggest a kit like STAHL Masonry Kit 8mm Drill With 50mm Blue Wall Plugs but purchase a Sutton Tools 8.0mm Glass And Tile Drill Bit. If you are fixing to the timber frame or noggins (which I would prefer you do) then you could use something similar to Zenith 10G x 60mm Zinc Plated Hinge-Long Thread Timber Screws - 50 Pack.
I'd suggest you take the black mount into a store to assist a helpful team member in selecting the correct products for you. You might like to also enquire about options for just sticking the mirror on as is commonly done.
Please let me know if you need further assistance or had questions.
Hi Mitchell,
Thanks for being helpful.
I am planning to fix it to the noggins inside the wall. I believe I have to pre-drill a hole in the wall before I can use a timber screw? If yes, what type of drill bit? Should it be of similar size to the screw diameter?
Thanks again.
You'll be using a tile drill bit which is slightly larger than the shank of the screw. You'll want to run this drill bit at a relatively slow speed and have someone mist the tile with water whilst you drill through it. This keeps the bit cool and helps prevents it from becoming dull.
