Hi everyone,
I wanted storage in the bathroom, so I thought it was genius idea to place a storage box behind a round mirror that I had
purchase My husband did a good job putting my vision into light...
The problem is there is no stud on the wall to hang the master piece. Another suggestions on how to get around this. Thank you
Hi @stelz,
There should be a stud around every 450 or 600mm along that wall. They can be a bit tricky to find, and a stud detector will make quick work of locating them.
A couple of these GripIt 25mm Blue Plasterboard Fixings will do the job for you if you can't find a stud. Each one is capable of holding 60kg's. Alternatively, four Ramset 3 / 16" x 75mm Plasterboard Spring Toggle Anchors would also work.
