How to fix water drops from taps?
Sugar
Having an Impact
Hi Folks,
I am having shower tap leakage.
I had the washer replaced long time ago.
Do you think replacing the whole spindle could fix the problem ?
Regards
Re: Fixing water drops from taps
Hello @Sugar
It could be time to replace the washer again. I suggest looking at this guide - How to replace a tap washer. If after replacing the tap washer and the tap continues to leak, I suggest engaging the services of a licensed plumber to repair your leaking tap.
Sugar
Having an Impact
Thanks @EricL
I got it sorted out this time by replacing some internal parts. I am putting new washers or taps later in the future. Hence, for now, I wanted to work it out. I used Lubricant as well.
Changed them  on both sides :
Changed this too:
Put this new :
seems like it is fixed for now.
Water leakage has stopped.
