Hello there!
I have just moved into my first home and there are a few things to be fixed up in the bathroom. Would really appreciate it if someone could advise me on what to do as I am not very handy.
The shower tap is coming off the wall - how should I attach this back on? Is there a concern about water accumulating in the wall due to the hole?
shower tap not attached to wall
The soap dish twists round and round - should I put some sort of adhesive to secure it?soap dish twists round and round and round...
Lastly, there are a couple of pitted tiles (is that the right word for it?). Should I seal them up with epoxy or something?pitted tile
another pitted tile
Any advice will be much appreciated! I feel like these might be really basic issues but I don't have family near me to help, so I'm turning to the Bunnings community
Welcome to the Bunnings Workshop community @bergamotblack. It's wonderful to have you join us, and many thanks for your questions about bathroom repairs.
For the tap, have you tried screwing the cone-shaped collar back down against the wall? By screwing it clockwise, it should return to its normal position against the wall. You might like to scrape off the old silicone and add a small bead of new silicone under the collar before fully compressing it against the wall tiles. This silicone will prevent water from creeping down behind the collar and potentially entering the wall cavity.
I can't imagine many glues would adequately hold the soap dish in position in the shower. You could try some super glue or epoxy glue. Placing a small amount between the chrome and brass section could be enough to cease the rotation.
For the pitted floor tiles, it's more of an aesthetic issue than a problem you must address. You could paint the chipped area to match the surrounds better or seal them with the clear epoxy I linked above.
Thank you so much for your reply Mitchell!
