Christine12
How to fix broken tap head?
How do I fix broken tap head? What glue would be suitable or does it need replacement?
a broken tap head
Re: How to fix broken tap head?
Hello @Christine12
Thank you for sharing your question regarding fixing your tap handles. If the original handle has cracked or split in half, both handles will need to be replaced. I suggest using Shaw & Mason Clear PVC 6 Point Style Handles. It is similar in shape and has multiple spindle adapters included. I suggest having a look at this guide - How to replace a tap washer.  In step two you'll see multiple handles being removed, your one is similar to the last handle at the bottom.
The plastic handles often have a cover over them and a nut holding the handle in place. Once the brass nut is removed you'll be able to pull the handle off.
