Hi - my cabinet door has broken as the hinge has detached from the joinery. What is the best solution here? Is builders bog the best approach? Will it fix to the chipboard inside the joinery?
H
Hi @hamdcam,
The best approach, like you already seem aware of, is to fill the two outside holes with Builders Bog, allow it to dry then redrill the holes and reinstall the hinge.
Builders bog is extremely strong and will fix to the chipboard easily. I have actually done this exact repair in my own home, and it has been holding strong for the last few years with no issues.
