How to fix aluminium panel corrosion caused by cleaning chemical?
KMac89
I accidentally damaged the aluminum panel in my shower. This was caused by a cleaning chemical. Please can you help me how I can fix it?
Re: how to fix aluminum panel corrosion caused by cleaning chemical
Hello @KMac89
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your shower aluminium frame.
The cleaning chemical has stripped the cover layer of the aluminium frame. Due to the intense heat and moisture generated inside your shower cubicle any paint used on the shower frame will not last long in that environment. It is technically a cosmetic damage and will not affect the performance of your shower frame. I suggest engaging the services of a shower installer who might be able to resurface and polish that part of your shower frame.
KMac89
Thank you, @EricL !
are you able to recommend products I can use to DIY? Maybe spray paint?
Hi @KMac89,
As @EricL has mentioned, there are no paints designed to withstand the high-humidity environment of your shower stall.
You could try sanding the area with wet and dry sandpaper to make its appearance more uniform. You'd then likely need to polish the angle to restore its shine.
Be very careful working around glass as it can shatter easily. Wear PPE, including safety glasses, a long-sleeved shirt, trousers and enclosed footwear.
KMac89
Thank you both @MitchellMc @EricL  sanding the area and painting using pen paint worked. :smile: thanks again!
@KMac89 what pen paint did you use? I have a similar issue with my shower.
Hi @maravd23,
Hopefully, @KMac89 will respond shortly with an answer to your question.
If you want assistance from the rest of the community, you might like to create your own post with some photos of the issue so that our helpful members can offer assistance based on your specific circumstances.
Let me know if there is anything that I can assist with.
KMac89
Hi @maravd23
I used sharpie silvery. You can skip the sanding. I suggest trying on small area first.
