Hello I have to replace a cracked floor
tile I believe they came from bunnings originally can you tell me if they still make them the size is 300x300mm thank you
Welcome to the Bunnings Workshop community @Markreilly. It's brilliant to have you join us, and many thanks for your question about replacement tiles.
Without a brand or identifying code it would be difficult to determine what this tile is. From our current range there are some similar options: Duratile 30 x 30cm 0.99m² Fog Ceramic Floor And Wall Tile, Johnson Tiles 300 x 300mm Cosmic Graphite Matt Ceramic Floor Tile and Johnson Tiles 300 x 300mm 1.08m² Grey Rustic Tiles. You might also like to check out the range from our friends Beaumont tiles.
The closest we have would likely be the Duratile 30 x 30cm 0.99m² Fog Ceramic Floor And Wall Tile. It might be best to pick some up and compare side-by-side.
Here are some helpful guides: How to lay floor tiles and How to grout tiles.
