How to cover up the net on the window
Maymay
Building a Reputation
Hello Bunnings experts
Recently I want to cover the net on the window in the toilet , it causes wind and dust through year, what materials can I cover it
Thank you
Best regards
May
may
JaneK
Retired Team Member
Retired Team Member
Re: How to cover up the net on the window
That definitely sounds less than ideal @Maymay. I am wondering whether this is the only source of ventilation in the toilet? Let me tag @redracer01 and @MitchellMc who may be able to help with some suggestions for you.
Jane
Found the answer you needed? Mark it as Most Helpful
Maymay
Hi JaneK
we also have an exhaust fan too, I believe it will be ok if I cover up the net.
Thank you
maymay
Hi @Maymay,
It's good to see you're onto the next project!
What does it look like from the exterior? It might be easier/look nicer if you covered it from outside. If you wanted to fix something to the interior, perhaps you could cut some Australian Handyman Supplies 1200 x 600mm 0.75 Galvabond Mini Sheet to fit the gap with tin snips and pop-rivet it in place. It could then be painted to suit the rest of the frame. Alternatively, you could use CustomWood MDF 900 x 600 x 3mm Standard MDF Panel if you painted it as we can cut it to size for you in-store.
Maymay
Hi Mitchell
yes! Another project for me 😊, I think I am very popular to ask the advice 😅
I don’t want to cover up the whole window ( the glass part is ok, only the top side with the metal net has to cover to avoid the wind and dust )
Regards
Maymay
Hi @Maymay,
I believe covering this hole from the outside would look the best. I'd recommend using the  Australian Handyman Supplies 1200 x 600mm 0.75 Galvabond Mini Sheet to fit the gap, cut to size with tin snips and pop-riveted in place. You could also use some 110 x 19mm x 1.8m Tasmanian Oak Dressed All Round DAR Select Grade cut to the frame's width. You can then pre-drill the timber and frame and fix the timber in place with Zenith 10G x 40mm Gold Passivated Countersunk Head Metal Screws.
Maymay
Hi Mitchell,
Thank you for your information, I really don’t want to cover whole window, any more suggestion like a temporary tape only cover the net then I can change for every 6 months ?
Regards
Maymay
The method I've described above would be just for the gap, not the whole window, @Maymay. For a simple solution, you could just apply T-Rex 101mm x 1.5m Strong Waterproof Tape to the exterior. I'd imagine the tape would last for several years.
Maymay
Hi Mitchell
I prefer the simple solution, it is much easier for me
Thank you very much
Regards
Maymay
