Hi
G’day people.
first timer here.
i want to connect my 2nd washing machine in alfresco.
there is one water point for the sink. Is there a 2 way valve I can replace to connect water inlet to both my washing machine and also to the sink tap?
it is the left cold water valve
Hi @vini
A Y adaptor may siut your needs if your wshing machine hose long enough. If not get a longer one.
https://www.bunnings.com.au/boston-3-4-washing-machine-y-hose-adaptor_p4920358
I/N: 4920419
$26.10
Thanks. Is the size of the female thread same for washing machine and sink tap connections?
hi @vini
The fitting states 3/4 inch outlet so it should fit your existing setup.
You may need one for hot water one for cold inlet.
Note some washers heat there own water so you only need cold water inlet.
Hi @vini
Welcome to the Bunnings Workshop community. It's wonderful to have you join us, and thanks for sharing your question about connecting your washing machine.
Just to add to the suggestion made, I recommend using the Pope 2 Way Brass Threaded Tap. It's brass body makes it very strong and there are integrated shut off valves if you need to turn one side off. Looking at the picture you posted it appears that the fitting is 3/4.
However, before you go to the store to buy the parts you need, I suggest measuring the diameter of the hose joints? just to be on the safe side.
