I am a beginner and would like to replace the toilet bowl seat with an electric bidet. And I realized that I had no way to remove the seat fixture, as the bowl was somehow concealed. Is it easy to remove it? Do I have to remove the tank or the entire bowl? Thanks!
Hi @rekeno,
You might have already done so, but check under the edge of the toilet directly beneath the two fixtures. There might be a nut there that you can undo. If not, take a small flathead screwdriver and lift the circular chrome cap on the fixture. There's a good chance it's a cover plate that will lift off the fixture and expose a large screw. Once the screw is undone, you can remove the mounting fixtures and install the new mounting fixtures supplied with your bidet seat.
Please let me know how you go and if you have any questions.
