Options
How to change tap washers?
March
how do I change the washer on this tap
Re: How to change tap washers?
March
Welcome to the Bunnings Workshop community @rudyjiggs. It's a pleasure to have you join us, and many thanks for your question about changing a tap washer.
You might like to have a read through this helpful step-by-step guide: How to replace a tap washer. Basically, you'll start by turning off your water and unscrewing the cold water button on top of the handle. You'll then pull the handle off exposing the spindle, which once again needs to be removed. Once the spindle is out you'll have access to the washer for replacement.
You might also like...
Subject | Author | Posted | |
October | |||
July | |||
July 2021 | |||
October 2023 | |||
April 2023 |
You might also like
JoJo133
