How to add another toilet?
Lisac
I am wanting to divide my toilet bathroom into two separate bathrooms. My question is, is it possible plumbing wise to add another toilet and where would it be located? My wall to divide the space will run from the existing toilet door across to the other door, so needing another toilet on other side of wall? The door in the left is the toilet then door on opposite wall is where wall would divide the room, so need new toilet in vanity side of room, happy to go to a 60 vanity and there is a cupboard behind door entry that I can go into if req. thank you
Re: adding another toilet to make 2bathrooms
Welcome to the Bunnings Workshop community @Lisac. It's wonderful to have you join us, and many thanks for your question about dividing a bathroom.
We're likely going to need a top-down sketch of the new proposed layout with dimensions to really work out whether it is possible. You can squeeze a shower, vanity, and toilet into a tiny footprint to achieve what you require. It just depends on what type of sacrifices you're willing to make. Guessing at your footprint, I'd suspect you'll need to go with at least a slimline vanity and even then, it's going to be relatively tight.
Here's a quick rendering of a possible layout.
We'll be looking forward to seeing your sketch of the room and hearing those dimensions.
