I'm looking to buy a place, my main bone to pick is the ensuite - its tiny with Bath and basin - no toilet.
The way i see it I have two options
1. Somehow convert the bath to shower and create room for toilet - what are my options here and would it be costly?
2. Knock down the wall between ensuite and laundry to expand the size of the ensuite. Obviously this means remove the placement of the bath/change to shower, this create space to install toilet.
Any advise for both options and what my very basic costings might be?
Welcome to the Bunnings Workshop community, @Kingleviathan. It's great to have you here, and many thanks for your question about adding a toilet to your ensuite.
Between your two options, converting the bath to a shower and creating space for a toilet would generally be the more straightforward and cost-effective approach. Removing the bath will free up significant space, and a compact shower can be installed along with the toilet. This option avoids major structural changes and would likely be quicker to complete, though you’ll need to ensure the plumbing is properly adjusted to accommodate the new fixtures.
Knocking down the wall to expand the ensuite into the laundry is a larger and more invasive project. It could give you more space, but you'll need to account for rerouting plumbing, electrical work, and the cost of rebuilding the space. This might also impact the functionality of your laundry area, so careful planning is essential.
Unfortunately, it’s hard to provide exact costings as it depends on the specifics of your space, materials, and labour. I'd recommend getting quotes from a few bathroom specialists to get a clearer picture of the costs involved in either option.
Feel free to ask if you have any further questions or need more guidance.
I have a small ensuite which i measured as 1.6m x 1.6 from wall to wall. It has a sliding door
Can i fit a shower, toilet and basin with the needed space around each to confirm to code requirements?
Hi @Kingleviathan,
Thank you for your question.
The only information I can find about bathroom spacing requirements is related to disability access in new builds, not renovations.
You can physically fit everything in a 1.6m x 1.6m bathroom, but there isn't definitive information that I can link to. I'd suggest it is possible, but I can't say whether it is advisable under relevant building standards.
I'd suggest this might be a question best asked to a plumber or builder. They will be aware of the spacing requirements and be able to tailor a solution that fits within requirements.
