How to Fix Cracks and Missing Grout in the Shower
Josh86
Hi, I’ve noticed a few cracks in my shower grout. Some are just hairline cracks in the grout at the base, while one section in the wall corner appears to be missing grout altogether. What’s the best way to fix this?
Re: How to Fix Cracks and Missing Grout in the Shower
Hello @Josh86
Thanks for sharing your question about your tile grout. I suggest using a QEP Professional Grout Saw to remove all of the defective grout. Once you have cleaned the tile gaps, I suggest using Dunlop 800g Ready-To-Go Coloured Grout to fill in the tile gaps. To flatten the grout, I recommend the QEP 6" Handyman Squeegee. Please remember to clean the surface of the tile with a large sponge as you go.
Here is a handy step-by-step guide: How to grout wall tiles.
Thanks for the detailed advice! I appreciate the product recommendations and the step-by-step guidance. I’ll definitely give this a try and let you know how it goes! Just wondering—do I need to remove all of the grout on the floor, or can I just scrape away the cracked areas and refill?
Hello @Josh86
You can remove just the damaged areas especially if it appears that most of the grout is still in good condition. But if it is dusty and it looks like it is starting to deteriorate, then it would be best to remove those sections as well.
