How do you remove the built up stains on a glass shower cubicle?
Hello @neale
Welcome to the Bunnings Workshop community. It's marvellous to have you join us, and thank you for sharing your question about your glass shower.
If the calcium deposits have built up on the glass, I suggest using CLR 750ml Bathroom And Kitchen Cleaner. Please make sure to give the CLR enough time to activate and break down the calcium. I also propose using a Trojan Safety Scraper With 5 Blades, just make sure that you don't dig the corner of the blade into the glass, or it will leave a very large scratch and damage the finish.
To finish off the cleaning, I recommend using Mr Clean Eraser Pad Block. Please make sure to soak it in water and never use the foam when it's almost dry.
Please make sure to wear personal protection such as gloves, goggles and a mask when using the chemical cleaners.
Here is a link to our best advice: Best tools to clean glass shower door
