How do i replace the mirror on a bathroom cabinet?
Rob81x
I have the wall mounted cabinets that are frameless mirrored doors and want to replace the mirror? i cannot see any obvious way they are attached and think they may be glued?
Is there a way to replace this mirror or is a whole new door required?
thanks all
Re: How do i replace the mirror on a bathroom cabinet?
Hello @Rob81x
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your bathroom mirror.
Please note that working with glass is quite dangerous, an errant hit with a tool or if too much force is applied could cause the mirror to shatter l
Often times mirrors are usually glued in place to prevent it from accidentally falling out. Some manufacturers sandwich them in between timber to secure them. Can you please provide a photo of the mirror frame itself? This will give our members a better idea of how the glass was put into place. We can then make recommendations on how to proceed.
Rob81x
Thanks EricL, please see below. The glass is stuck down solid. i am not sure its designed to come off in once piece, if at all.
