I need to reseal the area between my bath and the wall tiles. As you can see from the pictures the entire bath area needs redoing.
I also have a problem with the "grout/cement" sealing between the glass bricks and the window tiles. This started as a small hill on the sealant area but is now growing and spreading.
I would like to know the correct products to use and correct use of these.
Thanks for any help you can give me.
Caro
Hi @Caro,
Both areas seem to show quite a heavy build-up of a calcium-like substance. The nodules of build-up at the glass tiles can be chipped away with a flathead screwdriver, and a thorough cleaning of the tiles at the bath should remove those deposits. Once they are gone, you can use a silicone sealant to fill any cracks that water might be leaking out of or into.
You'll likely find that a good scrub down every couple of months should prevent this build-up. We have a variety of excellent general-purpose cleaning products which you can use for this. I'd recommend something like CLR 750ml Bathroom And Kitchen Cleaner as it specifically targets calcium.
Hello @Caro
It's great that you've received excellent advice from @MitchellMc. Just to add to the suggestions made, it looks like it's time to put on a new silicone bead where the tile meets the bath.
