Hi, these tap heads are common as dirt but I seem to be stuck at square one with removing them!
I've tried pulling hard, inserting leverage between the tap and the wall and leaning on it viciously, and banging the knobs hopelessly with a hammer. Astonishingly, none of these tried and true methods have worked so far.
Any clues would be very much appreciated!
Thanks,
Neil
Hello @Nello
Welcome to the Bunnings Workshop community. It's splendid to have you join us, and thanks for sharing your question about removing your tap heads.
It appears that the handles have binded themselves to the spindle of the tap. I suggest trying one more technique. Using your hammer, I suggest tapping the skirting edge of the handle all around. Your objective is to get the handle to move sideways. If you wisht o protect the tap I suggest putting a rag or light shirt over the handle before tapping it in.
Binding often happens when the calcium in the water settles between two surfaces. In this case it's the handles interior body and the spindle itself.
You can also try spraying CLR Ready to Use 750ml Calcium Lime Rust Remover. This is an excellent spray that should soften up the calcium.
If it refuses to budge, I suggest engaging the services of a registered plumber. They will have the equipment that will allow let them to remove the stubborn tap handle.
An automotive gear puller could apply sufficient separating force to the tap shaft & remove the handle, letting some penetrating oil soak in the cavity would also be prudent, failing ownership of said specialist tool perhaps (as already advised) contact a Plumber.
Welcome to the Bunnings Workshop community @DIYGnome. It's sensational to have you join us, and many thanks for jumping into the discussion.
A gear puller would certainly be an excellent tool for removing suck tap handles. I'd agree that letting some penetrating oil do its work before attempting the pull would be a great choice.
We look forward to hearing about your projects and plans around the house and garden. Please reach out anytime you need assistance or have something to share with the community.
Thanks @DIYGnome - great advice. I actually have one of these and have now used it successfully to remove the handle!
