There is gap between my laundry door and the door frame. But it’s only at the lower section of the door. I have the weatherproof seal on the door frame and the door closes fine. But there’s a gap because I can see light passing through. What I can do to fix the gap?
Hello @redcamper
It appears that only 3/4 of your weather seal is actually making contact with your door. If the door is not off balance and is not hitting any of the corners when it is being used, I recommend leaving your door in its current position and just adding more weather seal for ease of repair. I suggest using Moroday White Self Adhesive Weather Seal on the bottom right-hand side of the old door seal only. There is no need to cover the entire area with a new seal. The new weather seal will easily cover the gap, and you'll have a fully sealed door.
My best advice is to wipe the area with isopropyl alcohol before putting the new weather seal beside the old weather seal.
