How can I paint wooden window frame?
ELI5
Cultivating a Following
Please how can I repaint window frame here  including metallic winder white colour. Thanks
Jewelleryrescue
Re: How can I paint wooden window frame white
Hi @ELI5
Painting that frame and winder is  pretty straight forward.
You seen the sanding blocks?
Grab one of them and lightly sand the old paint this will clean it and knock off any rough bits  all in one go.
Now use an outdoor acrylic  paint as the should last 20 years in the sun. Grab a 30mm wide brush and off you go 2 coats an  hour apart on a  warm  day.
Ps no need to sand metal  just paint you may want to mask off the glass and anywhere else for clean  paint lines and inside use drop sheet n the floor.
Sanding block
Exterior  paint comes in semi gloss, low  sheen  and all the colours of the rainbow so  have  fun.
Example
ELI5
Thanks, do I use same paint for exterior for the interior and winder as well?
ELI5
Also link to the sanding block is not working, can you please resend?
It's great to see that @Jewelleryrescue has already provided some helpful advice @ELI5.
For the window winder, my preference would be to give it a sand to scratch the surface up slightly and spray it with enamel paint. It's much better at withstanding knocks and damage than the water-based exterior paint. If you want a product that will do both the inside and outside, I'd go with Dulux Aquanamel.
Here's the link to the sanding block.
Please let us know if you have further questions.
