Do you need to silicone an Oliveri laundry tub?
suhu6
When installing an Oliveri 70 litre Drop in Laundry tub onto a stone top, do you need to silicone around the tub or just use the clips with the sink to attach it to the stone top?
Re: Installing an Oliveri Laundry Tub
Hello @suhu6
Welcome to the Bunnings Workshop community. It's wonderful to have you join us, and thanks for sharing your question about installing your Oliveri laundry tub.
I suggest placing a bead of silicone on your stone top and pressing the laundry tub onto this in order to get a good water seal. Once the tub is locked into place, I propose putting another bead on the surface to totally seal the tub to the face of the benchtop.
suhu6
Thankyou Eric, the reason I was asking is because the laundry tub has a rubber seal all around the underside, which when the clips are in place should seal the underside of the sink. So would it still be necessary to use silicone? ( I'm not sure if all sinks have the rubber seal or not? ) Thank you for your help. HelenSee the rubber seal here all under the sink.See the rubber seal here all under the sink.IMG_1969.jpeg
Hello @suhu6
I tend to over engineer my projects. I would still put a bead of silicone behind the rubber seal just to make sure that it is totally sealed from water. But I will leave that choice up to you.
