Correct fitting to connect a floor outlet to a PVC pipe?
landlord
I have a disconnected floor outlet. This is not for a shower, but for a run off for water being used to wash the bathroom floor, or for water spillages.
What connector is needed to fit the outlet to a PVC pipe?
The PVC pipe in turn would then be connected to the plumbing for the bathroom.
Kindest Regards,
Jean-Marc Bany.
JMBany
Re: Correct fitting to connect a floor outlet to a PVC pipe?
Hello @landlord
The wastewater coming from this waste must be directed properly to the wastewater runoff. Only your plumber can link this pipe properly to your existing plumbing in your property for safety and compliance. The plumber will probably add bends and pipes so that they can link to your existing waste pipe in the ground.
Good Evening Mr EricL,
Thank you for kindly confirming, and for taking the time to respond, you have been most helpful.
Kindest Regards,
Jean-Marc Bany.
JMBany
