Hi Can you advise if the estilo semi frameless shower screen is suitable for the Decina Prelude shower base? Both are 900 x 900mm.
Let me extend a very warm welcome to the Bunnings Workshop community @gregmirella. Feel free to post anytime you need a hand or have a project to share.
Our resident Bunnings D.I.Y. expert @EricL will be happy to assist you with choosing the right products for your bathroom. He will get back to you as soon as possible.
Hello @gregmirella
Thanks for sharing your question about the Decina Prelude shower base. Please allow me to double check the size of the base lip of the Estilo shower base. As soon as I have the measurements, I'll get back to you as soon as I can.
Thanks Eric
Hello @gregmirella
Thank you for your patience. The Decina Prelude has the same lip dimensions as the Estilo 900mm x 900mm Shower Base 4 Lip Rear Outlet. However, the Decina is technically 5mm bigger than the Estilo base so the the shower frame might be sitting on the edge of the Decina's lower lip. I propose opening the Estilo shower box carefully and test fitting the shower frame on the Decina shower base.
Please note that the Estilo shower frame is adjustable, and I recommend maximizing its allowable width and length so that it sits neatly on the lower lip of the shower base.
Ok thank you
I was wondering my bathroom is hated by my partner and I because we need a bigger shower and I’d like floor to ceiling tiles +double shower n new style drain. Can I (because I’ve already gapped/ fixed all holes n painted, so can I just cover everything in waterproofing and then just cement new tiles in, can I do that legally.….."”¿or Moreton it is that acceptable "”?
Hello @CamSmith
Welcome to the Bunnings Workshop community. It's wonderful to have you join us, and thanks for sharing your question about your shower project.
Before you go into waterproofing, I suggest checking the fall on your floor to make sure that water will flow to the floor waste correctly. If it does not have the correct fall, it might be necessary to screed your existing floor in order to achieve the correct fall.
In regards to water proofing, I suggest checking the rules and regulations of your local council. Waterproofing will possibly need to be applied by a trained professional. The application will then need to be inspected and signed off before you can begin tiling.
My best advice is to check opening distance of your proposed shower area and make sure that there is glass shower panel door set that is available.
