Can you recommend anything?
Existing pan measurements | ||
Measure existing pan | mm | |
fixing point to fixing point | 165 | |
centre of hole to fixing point | 420 | |
back to front | 220 | |
side to side inside | 280 | |
side to side outside | 370 |
Welcome to Bunnings Workshop @davidwoosh. We're pleased to have you join the community and trust you'll get plenty of help and inspiration for all your projects from our members.
Thanks for the measurements of your pan. Let me tag one of our resident Bunnings D.I.Y. experts @EricL to assist you as soon as possible.
In the meantime, have you seen the guide How to choose a new toilet seat?
Thanks again,
I have been on the bunnings website for a couple of days trying to find the size and shape. My unit is top fixing and one screw broker. Then i bought a kinetic fixing kit from bunnings and it didnt work. the bolts would not tighten. So i am keen to get a recommendation from the resident plumbing expert if possible
Hello @davidwoosh
My apologies for the late reply. Would it be possible for you to post a photo of your toilet seat open/closed and its hinges. There are a few types of "U" shaped toilet seats available, so I'll need to see exactly what you've got.
The best way to get a really close match is to bring your seat to the store. From there you'll be able to tell if the fixing points, the length, width and height are compatible. Unless you are aware of its make and model the best we can do is a close match.
For example, if it is a Caroma Luna toilet suite, we can do a special order for the the Luna toilet seat so that it fits perfectly. I propose doing a bit of investigation and see if you can identify your toilet suite.
