My daughter & I are planning to instal new cupboards including trough in the Laundry. We're using Bunnings flatpacks. Are we able to have an opening pre cut in the cupboard end nearest the washing machine for the power cord & W/m hose, and also in rear panel of same cupboard to accommodate new power point & tap connection for W/m? Can the bench top be precut to house the trough in new cupboard?
Welcome to the Bunnings Workshop community @DianeS. It's wonderful to have you join us, and many thanks for your question about pre-cutting cabinetry and benchtops.
Those types of cutouts would typically be done whilst installing the products, and our supplier doesn't have the ability to pre-cut cabinets or benchtops. This is partly due to needing some very specific and accurate measurements in order to position the cutouts correctly, a centimetre or two off, and it could ruin the benchtop or cabinet.
Our helpful members would be more than happy to guide you through the process if you wanted to give it a go yourself, or if you're having the cabinets installed, you could speak with the installing to see if they can make the necessary alterations.
Here's a helpful step-by-step guide on Cutting out benchtops for sinks and cooktops.
