Can you change location of Kaboodle cabinet legs?
georgia_f
we are doing a small laundry reno (over a cement slab). The layout will have a centred  450mm cabinet with sink, then space for washing machine and dryer on either side.
have a 450mm base kaboodle cabinet and one of the back legs is currently positioned right over the water waste pipe. Can I relocate this leg to a more central position out of the way?
Re: changing location of kaboodle cabinet legs
Hello @georgia_f
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about the Kaboodle cabinetry.
Yes, you can move the leg closer to the center of the cabinet. However, I recommend anchoring the cabinet to the wall so that there will be no possibility of movement.
