Welcome to the Bunnings Workshop community @RJO. It's wonderful to have you join us, and many thanks for your question about connecting a washing machine.
It sounds entirely possible to connect your washing machine here. The higher taps are connected to the same water source as the lower ones, so I would just run them into a bucket to eliminate any debris. Connect your inlet hoses here once they flow clear water, as they already have threaded fittings. It will be a real pain trying to connect to the lower taps as there is no way to screw on your washing machine hoses.
Once the washer is connected, you just need to turn the taps on and not touch them again. Use a set of pliers to turn the tap on without a handle.
Regarding the waste pipe, see that white pipe under the sink? Can you check to see if there is a little white spigot with a barb coming off it? Also, check to see if this spigot is drilled out inside it. Your waste hose pushes onto it and needs a clamp to hold it in place. If there is no spigot I suggest screwing one of these U-brackets into the timber right next to the sink. The bracket will hold your waste pipe and direct it into the sink.
