One of the globe in bathroom has suddenly stopped working.
I brought a new one and still the same.
Then tested the socket with the tester and can see power is there.
Please see the attached pics.
Can someone please advise what may be the problem. Thanks in advance.
Hi @Abhi352,
There is an issue with the control gear that is supplying that lamp.
You need to get a qualified electrician to investigate this further.
Mike T.
Hello @Abhi352
Thank you for posting those photos. I totally agree with @MikeTNZ's assessment, you'll need to engage the services of a qualified electrician to have the fault investigated. Unfortunately, the other parts of your lighting system can only be accessed and repaired by a registered electrician.
