1/4 turn taps sit proud of the wall
MichaelGuinane
I have installed a 1/4 turn tap but it sits about 20mm proud of the tiles.
The assembly does not seem to have any margin for adjustments to shorten.
Obviously I don't want the expense of a plumber breaking tiles to resess the internal pipework a further 20mm.
Are there shorter assemblies or flang/shroud extenders. Or some other means to fix this issue.
Re: 1/4 turn taps sit proud of the wall
Hello @MichaelGuinane
Welcome to the Bunnings Workshop community. It's fantastic to have you join us, and thank you for sharing your question about covering the gap on your wall taps.
I suggest having a quick look at this discussion - How to add a flange to cover a proud bath spout? by @Barracuda. In the discussion, I suggested using either a Fix-A-Tap trouble dome or a Holman 50mm PVC DWV Push On Cap. The advantage of using a PVC push on cap is that you can paint spray it to the colour that you like and mimic a chrome finish.
The trouble dome needs to be ordered from the special orders desk. I've placed an image below for reference.
