Would you buy a Mitre Saw or Circular Saw first?
I am planning on undertaking some projects at home (build pool pump enclosure, replace battens) that I believe a circular saw will be able to accomplish. However I have some further projects in mind that may require a mitre saw so it had me thinking would I be best to buy a mitre saw to complete all works or is there something I am overlooking/not understanding between the two that would require me buy both.
Thanks in advance!
Re: Would you buy a Mitre Saw or Circular Saw first?
Morning @HunterProperty
Yeah I know that feeling of driving the saw off into the nevermore It actually comes down to practice amd muscle memory.
Using an offcut, sit it on a saw horse or bench and cut off the last say 7cm of the offcut, the timber should be wide enough that the feet of the saw rest on the timber as you cut. You will get more confident as you keep doing the cuts. The Saw itself will want to travel in a straight line once your muscles "remember" what you are doing. Whenever I cut some timber after a long period of time the first cut is always "not quiet right" bythe third cut its back to being confident. I extrapolate the line I have marked on the timber piece (Say im cutting a 90mm width) so as long as I have the blade start on the line and the pencil line I extend in my mind I can "see" its traveling straight.
The Torqued drill I have in the ozito range is Ozito PXC 18V Cordless Drill Driver Kit PXDDK-250C
Have a look at my privacy screen (fort) and especially step 2 Courtyard privacy fence and gate build, Part 2 as it explains why I prefer a torqued drill over an impact driver. I was going through hardwood decking into aged hardwood posts as well. So the impact driver sheered off the screws. Once I realised and it did take me a day or so then it went smoothly.
Thank you Dave! Ive bought some more off cuts today from bunnings to practice tomorrow. The price of ozito tools always floors me. Think ill invest in a driver kit.
Thanks Jacob,
Popped into bunnings today and bought a square and some offcuts. Will be practicing tomorrow. Thanks heaps for your help.
Hi Brains Trust!
Busy morning making a mess with the circular saw. I am seeing improvement in my cuts which is encouraging and I have been using a speed square as a guide. After a few test runs I moved onto the good timber to try my luck. Not a complete disaster but I am not happy with the result. A couple of pieces are a mill or two too long and the end is not perfectly square. Is there a way to correct the defects so I dont have to buy more timber? I suspect a planer or sander of sorts would be the go? Any advice is appreciated!
Evening @HunterProperty
A couple of mm really in the great scheme of things isnt a worry, you could always stagger the piece so the gap at one end is 1-2mm and the other end its the same? Sanding it will shorten it again so thats an out. You could use one of your shorter lengths for another spot that needs a shorter length?
Practice makes perfect. I look at my errors I have made (too short, wrong cut) as badges of knowledge And Tell people the story even
Work cut was 120mm too short..... I just wasnt paying attention and I was the labourour for my job and just doing the cuts as the carpenter called them. I handed the piece to him all proud of my work, he holds it up to wall and pauses, looks at me looking at him, holds it up again.... by this time I knew something had gone wrong lol ahhhhh live and learn, pay attention for me If you rails are too short then I would chalk up your timber as a learning cost
and buy a few more plus an extra for practice
Hello @HunterProperty
I can't count the number of times I was sure my cut was next to the line. For some reason the blade kicked to the left or a slight jiggle course corrected my hand. I can only advise to keep your eye on the line and keep your hand steady. It does not take a lot to swivel off course. Always clamp your pieces to the horse and if you can use a saw guide always take advantage of it. Keep practicing.
Thanks Dave!
Sorry just to clarify the pieces are a couple of mm too long. I am also a true believer in learning from mistakes so its nice to hear the same. I guess correcting defects in another skill in a sense so if there are any tips or tricks im more than happy to learn. Cheers
Edit: I should of clarified, the lengths I am using are $70 each so if a screw up too many times its going to be an expensive lesson!
Thanks Eric! I noted a marked improvement in one day so im confident ill get there. Thanks for the support.
hahahhaha Oh I know those mistakes. I would take a claw hammer with you or a small crowbar and stop off at one of the free pallets in light industrial areas, dismantle one and you will have a lot of free timber to practice on, plus end up with a load of ideas on what could be made!
If its that close, then I would also suggest to measure a piece at say 800mm, mark it, cut it normally. And then meausur it again. This is to see if you are consistantly haveing the same "extra" bit on yourcuts. It could mean that you are cutting on the right of the line instead of the left or on the line. Just a piece of knowledge that you will pick up with the more cuts you do. I cut so the blade is just left of the line that I marked.
I found this product on the Bunnings website. Looks to be what I need to remove some length and square up the cut. Any thoughts on this?
https://www.bunnings.com.au/ozito-125mm-140w-mini-bench-disc-sander-mbds-125_p0206740
Subject | Author | Posted | |
February 2024 | |||
September | |||
July 2021 | |||
October 2021 | |||
November |
