Hi @Kreezy
All PVC fitting are perfect for underground use The most important thing for you is to match the joining diameters to the gal fittings. yo are aiming for a close snug fit so glues and sealing agents will work best.
Measure your gal fittings and start looking for a pvc match is best way to go.
Welcome to the Bunnings Workshop community @Kreezy. It's brilliant to have you join us, and many thanks for your question about PVC pipe.
It's great to see that @Jewelleryrescue has already responded. To connect, you'll need to select the same size and suitable fittings. Taking a section of the Gal pipe into your nearest Bunnings store will make it easier to match it to an equivalent PVC pipe.
In accordance with Australian and New Zealand plumbing codes, only licensed plumbers are authorised to undertake plumbing or drainage work. While homeowners can handle minor tasks like changing a tap washer or replacing a shower head, ensuring strict safety standards and regulatory compliance is crucial. Enlist professional assistance for plumbing projects to safeguard your home and family.
I have had a plumber come and diagnose problems and fortunately I am able to assist with the trench digging work, provide suitable piping and fittings. The installation will be left to them to clip and connect. I also won't be removing existing galv, it will remain in the ground and walls for the time being.
That's great to hear @Kreezy.
If you can provide the diameter of the gal pipe and show us the connections you need to make, we can assist you with selecting products. Let me know if you need a hand uploading images.
I'm so sorry, @Kreezy. I just realised I referenced Australian plumbing restrictions when you're in New Zealand. I double-checked, and they follow the same rules as AU regarding any plumbing work that must be carried out by a licensed professional, but you're all over that anyway. 👍
I'll amend my above comment to be clearer and for the benefit of other NZ members coming across this discussion.
