How do you replace batteries on a Dolphin Mini Torch?
Johncr
How does one open Dolphin Mini Torch to replace its batteries and or globe.
Rgds
Re: How do you replace batteries on a Dolphin Mini Torch?
Welcome to the Bunnings Workshop community @Johncr. It's terrific to have you join us, and many thanks for your question about replacing batteries and a globe in the Dolphin mini.
From memory, the batteries are inserted the same as the larger model by unscrewing the black rubberised section at the tip. If you grip the yellow body with one hand and the black section with the other, it should unscrew anti-clockwise. Inside I believe the globe is accessed via unscrewing a knob, but that could be an older model. Once you have the end of the torch off, if you can post an image, I can advise you on access to the globe. Let me know if you need a hand uploading images.
How did you go @Johncr? Did you need any further assistance?
