It's nearly winter and the temperature is starting to drop, particularly at night. Unfortunately, when the temperature drops, our power bills tend to rise dramatically.
In the discussion below, please share your tips for saving energy and keeping your power bill as low as possible.
What are some of the ways that you save energy in your home?
Some good tips and tricks in this video:
My intent in this post is to offer guidance, but I'm aware that it may ruffle feathers.
There's been lots of discussion on how to tweak existing homes to conserve energy, or do things smarter, but I think it's even more important that people weigh up potentially higher energy consumption, when planning their renos.
If a reno will bring endless pleasure, & money's not an issue, then by all means go for it.
Unfortunately most people aren't in that position, but energy onsellers aren't selective, they'll happily supply the extra energy to customers that get seduced by consumerism.
If anyone plans to take out an insulated wall (as an example), & open rooms to the outside with expanses of glass, sliding or not, they will pay for the priviledge, & keep paying for it. Even double glazed can't match the R-rating of a well insulated wall.
I urge people to take caution when planning renos, they're costly enough to do as it is, without the extra burden of the ongoing energy charges that aren't going away.
While I like most of that video, suggesting the double glazed alumimium framed windows from the Bunnings catalogue, doesn't sit well with me.
Aluminium is a good conductor, so for the frame to be thermally insulative/effective, there needs to be an insulation barrier to separate the outside conductive frame, from the inside conductive frame.
As an analogy, it's a bit like using large uninsulated steel beams as the structural framework, then splurging on high R rated walls between them. The uninsulated steel frame, provides an easy path for unwanted heating, or heatloss.
If anyone has small wooden framed windows, forget double glazing, it's not cost effective.
For those with large aluminium windows, I'd highly recommend installing a persplex panel on the interior side of the frame, a small distance apart from the existing glass, making sure that the enclosed air gap is intimately sealed, so that the insulative value of the air gap won't be compromised.
I'm sorry Bunnings if I've put your nose out of joint, but this is a DIY forum, & if you promote expensive sub par products for customers to save money, I will pass on what I know, so that Workshoppers can make an educated decision.
The big one from me is to have a few rugs on the couch so I stay warm and cozy when reading or watching TV rather than being tempted to keep putting the heater on higher.
This is good news: http://www.domain.com.au/news/solarpowered-tesla-town-coming-to-inner-melbourne-20160721-gq9nbh/
Be great to see it become mandatory that new houses are built with solar panels and battery storage.
This is also great: Within the suburb will be communal charging stations for electric cars and interconnected bike paths.
I take it your refering to the Polar window and door range? I have been trying to look into them for the shed, while there is some info on the manufacturers page on windows the design page to order the doors has no info and limited options. Frustrating to the point of having a diy wooden option looking less stressful. With no store in SA having any of the range I can find the poor special orders people are stuck with the same lack of information. I don't see a way around a solid metal window transfering energy through the frame, it is a trade off to keep the gas seal...
Diy double glazing you do have to be careful of condensation in your air gap, humid days are a no no for making your seal and most of the pros use argon gas.
@Brad, I did some digging around after seeing your post about the lack of information regarding the Polar double glazed windows.
Here's their flyer pdf, which doesn't inspire confidence.
They are built to Australian standards, check out the COMPLIANCE section on page 4 of this link:
http://www2.polarwindows.com.au/Polar%20Windows%20Brochure%20Oct12.pdf
Here's the part that I'm referring to, so that there's no ambiguity.
