LG Fridge Water connector
Samara1
Having an Impact
I need to connect my LG 642l instaview french door fridge water connection with water tap
picture is attached below. both ends are not matching so which connector i need to buy to connect here. kindly help me.
Re: LG Fridge Water connector
Hi @Samara1,
Thank you for your question. Installing a fridge makes it seem your first home build is nearing completion, how exciting!
Start by measuring the diameter of the thread on the outside of your tap and the diameter of the thread inside your hose connector to confirm sizes.
You're going to need to use a threaded hex-reducing bush such as this Brasshards 25 x 20mm Brass Threaded Hex Reducing Bush
There are smaller versions like this Brasshards 20 x 15mm Brass Threaded Hex Reducing Bush which could also be what you are looking for.
When installing the reducing bush, wrap thread tape around the thread on your tap and then around the thread on the outside of the reducing bush to ensure a watertight connection.
