A friend purchased a house about 10 year old that has laminated timber through the kitchen living room and passage areas. A piece of the very thin top layer (giving the wood likeness) about 30 mm by 30 mm triangular shape, has broken off revealing the white surface below. The broken veneer would be about as thin as a hairspray strand! An attempt to glue it did not work. Any ideas how this might be easily repaired would be greatly appreciated
thanks and cheers
Welcome to the Bunnings Workshop community @Mazdarx. It's marvellous to have you join us, and many thanks for your question about repairing laminate flooring.
What type of glue did you try using? I'd recommend a two-part epoxy like Gorilla 25ml Clear Epoxy Glue. You'll need to remove any traces of the previous glue you tried. Only a little glue will be required, enough to wet the surface and no excess. You don't want any excess getting on the surface of surrounding boards.
If the white surface below and the bottom of the top layer are exceptionally smooth, you might like to rough them up slightly with 600-grit sandpaper. This will key the surfaces and allow the glue something to bite into.
Thanks Mitchell, but I think it is beyond that solution. The stuff that gives the wood appearance is too thin and brittle to sand paper, and it fractured as soon as I touched it. Is there any way of touching up/filling the white patch?
thanks and cheers
There are Waxstix Touch Up Crayons @Mazdarx, but they are generally designed for minor scratch and chip repairs. If the chip doesn't have much depth, the crayons can be used to colour the white area. Alternatively, you could have some enamel paint mixed up in a similar colour to the floor and blend the white area in.
