EllieBee
Cultivating a Following
How to remove window pelmet?
IMG_9795.jpeg  I am wanting to remove these pelmets as I want to install plantation shutters. I can’t see any screws or nails, so I don’t know where to start. Thanks!
EllieBee
Re: Remove window pelmet
@TedBear
I picked up a Ryobi multitool today and it is definitely helping to remove/smooth out all the cornice cement and adhesive on the pelmet. It isn’t perfect, and it is messy work, but requires 90% less effort than scraping it off.
I have had to stop frequently because the tool is getting hot and sometimes the blade gets stuck, but I would 100% recommend anyone try using the multitool!! I can’t decide whether buying the SDS hammer tool or the multitool has been my best purchase in all my renovation projects
Thanks for the feedback @EllieBee. It's great to here it's been successful.
TedBear
Kind of a Big Deal
Yes, they are more versatile and useful than they first appear to be. I bought a very cheap one at first, thinking I'd hardly use it... when it died from too much work, I bought a better one. Glad to know that you've been able to quickly move on with the project. It's looking good so far ...
EllieBee
Hey fellas,
After removing the pelmet, removing all the old cornice cement, and patching the holes I’m up to cutting my cornices.
I am using the builder’s edge mitre box and a handsaw. I’ve cut at a 45° angle for an internal corner but it isn’t lining up perfectly. Is this normal? Is this something that should just be filled with caulk?
This is the Gyprock 55mm coving. I flipped it in the mitre box and it is thicker on the side against the wall (I think that means it bevels inwards?)
Thanks!
Hello @EllieBee
That demolition job looks fantastic. It's possible that the cut could be slightly off. You can either manually trim the coving or just fill it with filler and sand it down. The choice is up to you.
