Hi everyone,
our house is 15 years old and there is a gap between the house and concrete path. How to fill the gap to prevent water damage the foundation? Thank you so much.
Welcome to the Bunnings Workshop community @jenniferji. It's brilliant to have you join us, and many thanks for your question about filling gaps.
That's an expansion gap between your house slab and the pathway. It's not a seal that prevents water from entering and is there to isolate the pathway and prevent cracking. However, the gap has widened, and the expansion gap is not filling the area. For aesthetic reasons, you could fill the gap with Sikaflex 11FC, but there's not a great deal of concern about water entering and damaging your slab. There are plenty of other areas around the home where sub-surface water will reach your slab.
I'd recommend cleaning out the expansion joint and caulking the Sika product down behind it until it fills the area. You can then run a gloved finger over it to smooth off the surface.
Hi Mitchel,
Hope you are well.
i have another DIY project. I want to put the caulk between the concrete pave and whole house above ableflex like the 2nd photo. Which product should I use 11FC or 11FC plus polyurethane adhesive sealant or other products? Also could I also have some tips please? Do I need to clean before I apply the silicone? Thank you in advance
Hi @jenniferji,
It's great to see you're getting around to this project and the drawing you've provided is spot on.
Since the time of your original post, I have done a similar project in my shed. You can see it here - How to fill a joint in a concrete slab?
You'll see that step one is cleaning up the crack, which is essential to getting a quality seal. I used a screwdriver to agitate any dirt that was in the crack and a Makita 18V Blower to blow it out. If you don't have a blower, you can use a pressure washer, or even a garden hose and a brush to clean the crack. You're aiming to create enough space for the Abelflex to sit in the gap nicely.
Once clean, use Abelflex and Sika Concrete Grey Sikaflex 11FC Purform with a sausage caulking gun to seal the gap. You'll need a fair bit of Sikaflex for a long gap like this, so grab a few. If any sausages of Sikaflex are unopened, you can always return them with your receipt.
In my project, I was looking to create a functional seal rather than one that is particularly aesthetic, so I've skipped this step, but using painter's tape to mask off your bead of silicone will help you get nice clean lines. You can see an example of this in How To Silicone Seal a Bath Tub.
Make sure you have rags and some soapy water nearby as cleanup is going to be very important.
Thanks Jacob. May I know what is the difference between 11FC purform and 11FC plus polyurethane adhesive sealant?
https://www.bunnings.com.au/sika-600ml-concrete-grey-sikaflex-11fc-purform_p0628966
Hi @jenniferji,
In simple terms, they are two progressions of what is more or less the same product.
To use an analogy, think of a 2023-model car, a 24 and 25-model car. They are very close to the same thing with some minor improvements.
Sikaflex 11FC is an older version that is no longer available, Sikaflex 11FC Plus is the next progression and Sikaflex 11FC Purform is the newest progression.
I couldn't tell you the exact difference in terms of chemical composition but, this should give you a good idea. As the cost is the same, I'd suggest using the Sika 600ml Concrete Grey Sikaflex 11FC Purform.
thanks jacob
Hi Mitchell we just finished caulking around edges of house. I'm interested in your comment "There are plenty of other areas around the home where sub-surface water will reach your slab" I'm on sloping block and eager to keep water away from my foundations. Are there areas I should be inspecting.
Hi @Deb2025,
Slabs sit directly on the soil, so they naturally maintain some level of moisture due to the surrounding earth. This moisture can migrate through the slab over time, which is why it's important to control water flow around your home. Brick walls typically have a dampcourse layer to prevent moisture from wicking up through the mortar and into timber framework, protecting your home's internal structure.
For a sloping block, I’d recommend focusing on the high side of the property. Water tends to flow downhill, so it’s essential to ensure that water doesn’t pool near your slab. You might want to inspect the grading and see if additional drainage solutions, like French drains or surface drains, could be installed to direct water away from the foundation. Keeping the ground around your slab properly graded and sloped away from the house will help to prevent water from reaching the slab and reduce the risk of moisture-related issues.
Hi Mitchell,
I have recently noticed gaps in between my house foundation and side concrete perimiter/walk. Looking at the sudden widening of the gap, I am very worried now.Especially if you look at the picture where you can see two pipe lines are there, and i am anxious that the movement of the concerte away from the house would not cause any problems to these pipes.
What do you think? Is it normal? How can i fix this problem?
Another thing that i have also noticed today, there is not much support on the other side of these concerte slabs. What i meant by that - on the other side there is fence and in between fence and slabs, there should be proper soil etc to prevent any movement or slides of slabs away from the house (please correct me). I have found on certain sections, the landscapping guys did not put proper amount of soli, only some wodden black chips. So it feels like there is not much of support.
I am not sure if that is also responsible for this or not.
Do i need to check with builder? pipes
pipes
