Does Bunnings sell reciprocating saw blades?
pauldavidson
I have a Black and Decker KS890GT reciprocating saw - do Bunnings sell new blades for this model?
Re: Reciprocating saw blades
Hi @pauldavidson,
Thank you for your question about reciprocating saw blades.
Having had a quick look through the user manual for your particular reciprocating saw, it looks like the blades are held in place by a locking pin, which is the same method that all other reciprocating saws I have come across use.
If you remove the old blade, there should be a hole in the attachment end like where I have circled above. If this is the case, then you should have no issues purchasing a replacement blade such as this Diablo 9" Fleam Ground Reciprocating Saw Blade. If you have some concerns, it might be worth bringing the tool in store with you to test fit while you're still in store.
