hey guys - i've been here asking a few related questions and some of the helpful answers are now leading me to this question.
I had new PVC windows fitted but i refused to have any timber surrounds.
After browsing the internet, most suggestions are to use plasterboard - But now it has been pointed out that any moisture resting on the plasterboard is not healthy so i would like to ask for advice on what i should use/do?
There are also suggestions to use insulated cavity closers, but i cant see how i would fit them as the windows are attached to the outside wall (double-brick). I don't want to use wood anywhere - Can i use PVC or something moisture resistant instead of the plasterboard?
As always, your help is massively appreciated and my hurting head will be forever thankful ๐๐๐
Both the corner edge to the several and up to the window frame @elbow . Clean finish that your plasterer can sort as its a pretty standard finish this days.
Shouldn't be an issue at all @EricL @elbow to have the edge finished without any timbers. The corners/edges like any other corner plasterboard edge are reinforced with external metal angles. Of course if they get a good knock they will be damaged just like any other edge. This is a standard edge for any plasterboard finish square-set or not.
Hi @elbow, all great suggestions in resolving your window surrounds, after reading all the comments, you certainly do not want to use timber , especially going to to expense of using pvc windows, I found some websites that use and supply pvc reveals, please see attached, I have also attached a pvc edging if you want to go the way of rendering and hard plaster.
https://www.upvc.com.au/products/reveals
https://www.networkbuilding.com.au/shop/pvc-reveal-trim-60mm-3-5mm-build-3000mm/
https://youtu.be/jWa0R8PeiAg?si=lIe5od1rzQhsiOtQ
Hope these will help you to decide.
super awesome, thanks for the links and advice ๐
