What paint to use for Atlantis swing and play set?
Liv95
We have just purchased this play ground from Bunnings for our daughter and want to know what would be the best paint brand to use on it if we wanted to paint it? Will not have a lot of shade so something durable!
Re: What paint to use for Atlantis swing and play set?
Hello @Liv95
Thanks for sharing your question about what paint to use on the Atlantis play set. If I recall correctly the Atlantis Playset has a protective coating on it already. It might be necessary to sand the surface down before painting. Please allow me to contact our provider and double check for you, before I make any recommendation.
Thank you for your patience.
Hello @Liv95
Thank you for your patience. The Atlantis swing set is actually a heat-treated timber with a regular stain placed on top of it. It will be necessary to sand the surface of the timber in order to paint it. I suggest having a look at the Dulux Weathersheild to paint the timber playset. Please makes sure that the paint has totally cured before allowing the children to use playset.
Liv95
Hey Eric,
You are amazing! Thank you for looking into this for me :smile:
if it doesn’t need painting I think it’s easier to leave it as is!
