What adhesive for driveway pavers?
Hey there,
looking for some advice on the most cost effective adhesive to use for sticking down 20mm porcelain pavers to a concrete paving base.
the driveway is already smooth so doesnt need any screed, but I only have 5mm of play to reach the garage level.
the driveway is not covered, and the pavers are 100mm square which will Be layed in a brick pattern.
would something like this be suitable? The area is roughly 7x5m
dunlop-20kg-rubber-modified-tile-adhesive
thanks in advance!
Pete
Re: Adhesive for Driveway pavers/tiles
Welcome to the Bunnings Workshop community @vote4pedro. It's brilliant to have you join us, and many thanks for your question about adhesives.
It would be best to check with the manufacturer of the pavers to determine the most appropriate adhesive. If these are our pavers I'd be happy to do that for you.
Using our Tuscan Path porcelain pavers as an example, when glueing the tiles down to a solid substrate like a concrete slab, you would first prime the surface with Dunlop 1L Multipurpose Water Based Primer and then apply your Dunlop 20kg Trade Resaflex.
Thanks for the quick response Mitchell !
yes the pavers are very similar to those you have linked.
will pick up the primer for sure, is there much difference between the “Resaflex” and “Dunlop 20kg Rubber Modified Tile Adhesive” ?
thanks again
Happy Easter!
Hello @vote4pedro
The Dunlop 20kg Trade Resaflex has a larger coverage by one meter, but Dunlop 20kg Rubber Modified Tile Adhesive contains recycled rubber. The Rubber modified adhesive is a little bit less than the cost of the Resaflex.
Thanks Eric!
thats what i thought, Resaflex was out of stock at my local so will give the alternate a go!
Cheers
