I need to build a small deck in my yard. 2.4m long by 1m wide. I'm planning on running the bearers the 2.4m span and then have joists every 450 between them. I think the joists can just be 90x35 H3 pine as they are so short. I'm just not sure what to use as the bearers. I can't really put anything down in the ground to break the span as it is on a slope, so ideally, I would like to span the full 2.4m. I had a look at the Hyne span table that a Bunnings staff member recommended here on another post I was reading, but according to the table, even the biggest size at 240x45 can only span up to 2.2m. So, I thought perhaps I can use two bolted together every 450. Any ideas on what would be the smallest size I could get away with if I used two of them? I'm trying to maximize clearance from the ground for ventilation and such. Unfortunately, the span table doesn't have this information.
Hello @wolive
Thanks for sharing your question about your decking frame. In order to give our members an idea of what that slope looks like, would it be possible for you to post few photos of the area? Once we see how steep the slope is we can then make recommendations on how you could possibly support the decking frame. The only frame I'm aware of that you might be able to use that is 2.4m long is steel. If you are curious how much it will cost, I suggest speaking to your stores special orders team and asking them about Steel Deck Products. These steel frames can be custom ordered to the size that you need.
