Quick cheap gate height extension
Prawns
Becoming a Leader
Installed as one piece, ready for a jigsaw cut straight up the guts and some sanding to gap the slats so they dont touch when gates shutInstalled as one piece, ready for a jigsaw cut straight up the guts and some sanding to gap the slats so they dont touch when gates shut
Only took a couple hours and was pretty cheap, I used paddlepop sticks as "spacers" but I wasnt sure whether to level the boards "truely" or whether to follow the same level as the gate which had dropped on one side lols.  I still have a little sanding to do to straighten out the ends.
I love the Bunnings AppI love the Bunnings AppGotta love the Bunnings Map as wellGotta love the Bunnings Map as well
The bits I usedThe bits I used
I had a length of steel I cut up and painted for use as bracketsI had a length of steel I cut up and painted for use as brackets
brackets up, I decided to use a "true level" instead of following the gate lines (gate has dropped over time and isnt level)brackets up, I decided to use a "true level" instead of following the gate lines (gate has dropped over time and isnt level)
Needs a bit more sanding to get the edges straight but its basically upNeeds a bit more sanding to get the edges straight but its basically up
Re: Quick cheap gate height extension
Hello @Prawns
Thank you so much for sharing that clever idea of gate extensions.
With a little bit of creative thinking and repurposing of existing materials, you've made quick work of this gate extension. Plus, it blends in so well with your house and existing gate. It's great that you've used the Bunnings Product Finder App to help you easily locate the item that you needed. I'm sure our members will take inspiration from this project and the fact that it was quickly achieved.
We look forward to seeing more clever ideas.
