Low-level deck with lights
nishadshah
Growing in Experience
I went through all the posts on this website to build this deck I am so happy with the deck. Adequate materials, equipment and the feeling of the completion is great.
It is a 36sqm deck,  6 x 6m deck with a step towards the garden. Started this project after Boxing Day in 2021 and completed just a night before Australia Day.
Materials used:
  • 45x90x6 metre long treated pine from Bunnings to create the base ( total 180mm height + 5 mm packer to create a seamless entry and exit height in alfresco). Added another layer of treated pine wood on top to create 185 mm height in opposite direction at 455 gaps
  • 5mm plastic packers so that the base is above the ground
  • Dynabolt 40mm on the concrete and 40mm galvanised screw in to the wood to create a ground base same direction as the Merbau wood stacking
  • 90 mm Merbau wood for 36 sqm
  • Holman home 4 pin lights 45 mm and used the 30 mm as well ( wifi controller is an investment but it is worth it)
I highly recommend buying a good quality table saw for the accuracy In wood cutting edges as well as 45 degree cutting.
self drilling screws.
Re: how to Build Lower deck
Hello @nishadshah
Welcome to the Bunnings Workshop community. It's wonderful to have you join us, and thank you for sharing your low-level decking project.
What a beautifully assembled deck. You must be very proud of your accomplishment. It's fantastic that our member's low-level decking projects were able to guide and inspire you to build your own. What is the overall size of the deck and how high is it?
The installation of the decking lights truly enhances the overall appearance of the deck. How long did it take you to assemble the deck? Any information you can share about your deck build would be much appreciated.
Again, thank you for sharing your low-level deck project.
nishadshah
I have just added few details as you have recommended.
 Please feel free to provide me feedback if I need to add more details on materials , photos , steps, if that will helps others like me.
Thank you for your kind words
regards
 Nish
We really appreciate those additional details @nishadshah. Your deck looks amazing and you must be exceptionally proud of your efforts.
Looking forward to you next project.
