Low-level deck on ground
Hi All,
I am new to this forum. Having seen some impressive decking projects and amazing member support, I was hoping I could get some helpful feedback on my idea of building a low level deck in my backyard!
The deck I want to build will go over the existing lawn shown in the below photos. Decking surface will be a continuation of the existing patio tiled floor.
Hopefully the below images show the transformation I am expecting to achieve!
The ground height below the patio surface ranges between 140mm to 200mm. With the small depth available, I thought of building the deck with 19mm thick decking boards laid over a 90mm deep frame supported on steel stirrup posts.
90 x 45 MGP10 H3 treated pine is what I am thinking of for the construction of the frame.
I have two ideas for the frame as shown below. Whilst Frame 1 may be more economical I think Frame 2 would be easier to build with the lower number of stirrup holes that need to be dug in the small backyard.
Frame 1
Frame 2
I would much appreciate it if you could let me know your thoughts on which approach is more sensible and structurally sound
Looking forward to hearing from you.
Many Thanks,
Janitha
Re: Low-level deck on ground
Hi All,
My apologies about the delayed response.
I used Google Sketchup for the 3D images.
The plans were done using Inventor.
Cheers,
Janitha
Hello @Janitha
Thank you for sharing that information, let me tag @BriggsyNZ to make them aware of your response.
Please keep us updated with your progress, we look forward to seeing your decking frame assembled.
- « Previous
- 1
- 2
- Next »
Subject | Author | Posted | |
March 2024 | |||
August 2021 | |||
August 2023 | |||
October 2023 | |||
August 2021 |
