How to use EasyDRAIN Pit Boss Connector in a rainwater pit installation?
Hey guys, I am doing a small rainwater pit install and I had a few questions about using Everhard EasyDRAIN Pit Boss Connector
I have a pit case and some dwv pipe
My first question is whether I slide the connector from inside of pit case to out, or from outside in? I would have surely thought outside in (otherwise it would be very hard to get the screws in from inside the case), but there is a comment on the pit connector page that I think states otherwise. Just wanted to confirm.
My second question is how do I best secure the dwv pipe to the connector? It slides in nicely, but how does it stay there? Solvent cement?
Thanks as always!
Denis
- Labels:
Plumbing
Tools and Materials
Re: EasyDRAIN Pit Boss Connector correct usage
Hey @MitchellMc,
I ended up going with your suggestion but took a bit more than a little slot but still have a strong connection. I could have taken the whole rim off since I’m using a 100m pipe but this drains quite well.
I thought I’d leave few pictures here if somebody runs into the same issue:
I could have gone a bit lower but was worried about going too low. Thinking about it now I would probably drill a small hole at the very bottom from the inside first and then make a hole for the pipe from the outside using that as the bottom edge if I did it again. Oh well… next time
Still drains quite well. I can live with this much water left in the pit
Anyways thanks for your help!
Hello @tom138
Thank you very much for that update. Your pipe connection looks good. My best advice is to make sure to put a generous amount of adhesive on both the connector and the PVC pipe.
- « Previous
- 1
- 2
- Next »
